Circuit that acts as an octal Full Adder (FA)
Discussion in 'Homework Help' started by twis19, Nov 30, 2010.
  1. twis19
    Nov 30, 2010
    I am need some direction how to begin this project; design a circuit that act as an octal full adder using only binary full adders.
    Input: A, B = octal digits; Cin = binary digit
    Output S = octal digit; Cout - binary digit
    can you suggest a starting point or additional resource to get started?
  2. tyblu
    Member
    Nov 29, 2010
    199
    16
    From which level are you starting? Do you design individual transistors (gate widths) and work up from there, or do you have access to higher level blocks? I would start by understanding a 'Full Adder', as you just need 8 of them. (For a ripple adder, at least; for a look-ahead adder, you'll have to do implement some extra circuitry.)
    http://en.wikipedia.org/wiki/Adder_(electronics)#Full_adder
    Homework should go in the homework forum.
  3. twis19
    Nov 30, 2010
    I will have to start the individual transistors and work way up.
    Thank you for your prompt feedback.
  4. tyblu
    Member
    Nov 29, 2010
    199
    16
    Can you implement a simple ripple adder instead of a look-ahead or other type? They are the simplest. A single Full Adder implements the following:
    Co = AB+ACi + BCi
    S = A(+)B(+)Ci, where (+) is NOR
    They can be implemented together with this circuit, using 26T (+4T for inverters):
    You will have to design the pull-up and pull-down networks to have equal strengths using gate widths, then daisy-chain 8 of them together.
