Circuit- Solving for Req
Discussion in 'Homework Help' started by J.live, Sep 12, 2010.
  1. J.live
    Sep 10, 2010
    35
    Solve for Req
    Attempt:
    The resistors in the middle can be added to total of 5v. So then then 5v +5v = 10v
    Then they are all in series 1.5+10+ 1.5= 12.5? What I don't understand is what do i do with
    Rx? or 12.5 is Req?
    Here is the circuit:
  2. J.live
    Sep 10, 2010
    35
    errr anyone?
  3. Ghar
    Mar 8, 2010
    655
    72
    It's been 20 minutes man, people don't just sit here waiting to answer.
    Why are you using 'v' as ohms?
    Anyway, Req seems to be the resistance in parallel with Rx, so Rx and the 1.5 ohm resistor aren't included.
    You made a mistake, the 4||4 + 6||6 branch is indeed 5 ohms, but that's in parallel with the 5 ohm resistor.
    Req = 1.5 + 1 + (4||4 + 6||6)||5
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Please clarify the question. If possible, copy it.
    Also, the unit of measuring the resistance is Ohm, or Ω, as its symbol is, not V, for Volts.
    Finally, while you successfuly added in parallel the 4 and 6 Ohm resistors, you added in series the 5 Ohm equivalent with the 5 Ohm resistance next to it, coming up to 10 Ohms. The correct way to do it is add them in parallel getting 2.5 Ohms.
    Give it another try!
  5. J.live
    Sep 10, 2010
    35
    Thank you Ghar and Georacer.
    Ghar, sincere apologies for being so impatient. Idk ,why I used v for ohms. As you can see I am a total noob at this stuff. Thanks again.
    Wait a minute.
    If Req = 1.5 + 1 + (4||4 + 6||6)||5 and (4ll4+6ll6)ll5 = 5 so isn't 5ll5 = 10? Since it is 1/5 + 1/5 = 2/5 = 5*2 = 10?
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    Please use the correct notation. We cannot understand what you are trying to pass along when you alternate / with * in the "2/5 = 5*2". And that's just one example.
    Other than that, you seem to have successfully calculated that (4||4+6||6)Ohms=5 Ohms, but you can't do 5||5 Ohms= 2.5 Ohms. Did you do the first conversion yourself or did you have another do it for you? Do you know how to add in parallel two resistances? It is not wrong to ask for help, but we cannot help you properly if we don't know the level of your understanding of the problem.
  7. J.live
    Sep 10, 2010
    35
    No, I did it on my own. / as in dividing * as in multiplying.
    So Req = 5?
    Nvm now I know how you got it. I was not using the definition for Req correctly. My level of understanding is awfully low in this area. But, I hope to comprehend it sooner or later. Thank you.
  8. Ghar
    Mar 8, 2010
    655
    72
    Parallel resistors are :
    5||5 = 1 / (1/5 + 1/5) = 1 / (2/5) = 5/2 = 2.5
    You wrote 2/5 = 5*2, that can't ever be true.
  9. J.live
    Sep 10, 2010
    35
    No, I know. I was under the impression that we have to drag the denominator up and multiply it by numerator. Totally discard my pre-concived notion. Like I said I was being impulsive and wasn't looking at it closely.
    Just flunked my first circuits quiz. I need to put in more time understanding this stuff. Thanks again
  10. Georacer
    Nov 25, 2009
    5,151
    1,266
    Yes Req=5 Ohms, but seriously, I advise you out of pure camaraderie alone: If you have any interest in electronics, do read a book on linear circuit analysis. It's the very basics you can start from. Any attempt to learn anything beyond that will be vein, because of lack of a steady base of knowledge. And a little work on math wouldn't hurt too. You just can't write 2/5=2*5!
  11. J.live
    Sep 10, 2010
    35
    So, what should i do? Drop and take this class next semester? Or should I study simultaneously ? There is another quiz next week. I won't be getting my refund since it's pass deadline but i wont get a grade penalty just yet.
    You are right it will be pointless in proceeding with a weak foundation.
    Do you know who is the author and edition ?
  12. Ghar
    Mar 8, 2010
    655
    72
    Personally I made sure I understood the most basic examples in the course as thoroughly as I possibly could, ignoring the hard questions. Once I got those down I'd go onto the hard ones... and I would find they no longer seemed so hard.
    It's going to come down to personal differences but that worked for me rather well.
    You don't want to carry forward bad habits. By doing it like this you convince yourself your problem is with new material rather than old which lets you move on.
    Circuit theory was one of those courses where I was always behind. I somehow scraped by and over time I completely filled in the stuff I didn't catch while taking it.
    Edit:
    I should also say that this often meant I was studying old chapters instead of the ones that I was about to be quizzed on...
  13. Georacer
    Nov 25, 2009
    5,151
    1,266
    I can't tell you if you should drop the course or not. I don't know how western educational institutions and their point systems work, since I (sadly) don't study in one of them, I 'm greek as my info page says. So I can't be of any help to your dillema and I wouldn't like to be held responsible for the final outcome. What I will take responsibility for is this: read any textbook that your college provides for the course we are talking about, ask the classmates that seem to do better for advice on study material and for any questions on exercises, well, you know where to find us.
  14. J.live
    Sep 10, 2010
    35
    That is very true but rather hard to apply for me. I have a bad habit of being impulsive and not get out of my comfort zone to actually understand the material.
    Yeah, I have never done this before and started to study for the quiz two days prior. Not a good choice I know. Now that I have a failed my first quiz and the next one coming up I feel like i am in an endless loop. Not sure if I should carry on with this
    class this semester.
    Thanks once again Georacer. Appreciate your help.
    Ghar, I will surely apply that technique.
  15. Ghar
    Mar 8, 2010
    655
    72
    I know that personally I wasn't even allowed to a drop course and if you failed it you ended up with an extra course the next year... an awful situation.
    Another big thing about doing easy questions is that you can usually manage them to some degree. You figure them out, get the right answer and gain motivation. Motivation is huge, probably the biggest thing.
    I did pretty poorly initially because courses like circuit theory are extremely tedious and my motivation was always interest level so I would barely look at the homework etc.
    When I got to the more advanced courses I was very interested and actually did homework ahead of time... I never thought I would do that.
