Circuit project
Discussion in 'Homework Help' started by garner29jr, Apr 5, 2008.
  1. garner29jr
    Apr 5, 2008
    I am in need of some assistance with my project.This project will consist of a low pass filter,a high pass filter ,and a band pass filter with resistors and capacitors. I'm having trouble getting started on it. If anyone can help me I need a response before the 11th of april.
    These are the specifications for the circuit.
    There is an input signal of a 2Volt peak to peak sinusiodal signal
    For an sinusoidal input frequency of 100Hz
    LED 1 should be on
    LED 2 should be off
    LED 3 should be off
    For an sinusoidal input frequency of 1 kHz
    LED 1 should be off
    LED 2 should be on
    LED 3 should be off
    For an sinusoidal input frequency of 10 kHz or above
    LED 1 should be off
    LED 2 should be off
    LED 3 should be on
    Some help will be greatly appreciated!!!!!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Once the filters are responding to their frequencies, the rest should be easy. How are the filters coming?
