Circuit Problem
Discussion in 'The Projects Forum' started by crivoli, May 6, 2006.
  1. crivoli
    May 4, 2006
    26
    Please help me!!!
    I have built the intercom circuit found at (
    http://www.uoguelph.ca/~antoon/circ/intercom.html ), but it does not
    work.
    Are the audio transformers necessary with the 8ohm speakers? I cannot get any noise on the line at all. No sounds comes out from anywhere.
    Any ideas?
    -Chad
  2. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Do you have the test equipment to make some tests?
    Have you measured anything? If so post what you measured ... and where you measured it.
  3. JoeJester
    Apr 26, 2005
    3,393
    1,211
    There is nothing wrong with the design by Jan Hamer. You need to check and see what you have done improperly.
  4. richbrune
    Oct 28, 2005
    106
    8 ohms = bc558b Kaboom
