Circuit & PCB design software
Discussion in 'General Electronics Chat' started by CVMichael, May 4, 2010.
  1. CVMichael
    Thread Starter Senior Member
    Aug 3, 2007
    416
    17
    Before I asked about PCB software, here, but now I have a slightly different question.
    I tried the FreePCB software, and I also tried the TinyCAD for creating schematics for my circuits.
    Both of them have the same problem, not intuitive, and difficult to find the parts that I am using. For example for TinyCAD, I don't understand why they list ALL the parts in one list, why can't they group the parts, and also if the part is not in the list, why can't they have a generic part so that I can just write the part# beside it ?
    Anyways, I found both of them difficult to use.
    Do you know of any better software that is out there ? and also if there is any software where I can do both, design the circuit, then automatically convert that to a PCB layout ?
    If it's not free, it's OK, I will try it out, and if it's not too expensive then I will buy it if it's worth the money
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I've been using Cadsoft Eagle for a few years now. It is not intuitive either, but once I got used to the quirks of it, I like it just fine. It's like anything else; the more you use it, the more you find the strengths and weaknesses of it.
    They have a freeware version available; it's limited to a single sheet per schematic, two layers for a board, and a board size of 3" x 4". That's enough for many hobbyists.
    There's a good tutorial for Eagle on Sparkfun.com.
    I think BMorse recommended a different schematic capture/PCB layout tool in the Resources forum - and there were a number of other recommendations as well.
  3. ShockBoy
    Oct 27, 2009
    186
    I use both Eagle on the Mac and Diptrace on the pc. Diptrace is free and it converts schematic into pcb layout. It has quirks as well, but they can be overcome.
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
    I second diptrace, I use it and find there is very little it can't do. It is also super easy to do.
