CIRCUIT OF WINDSCREEN-WIPERS
thanosgen
Joined Jan 15, 2007
11
hi I want to draw special delaycircuit that will imitate partly delaycircuit that leads the windscree-wipers of car. The circuit via a switch might work in 2 places and the exit of circuit will always be a vibration of duration of 2 seconds. In the first place I want the vibration it is repeated after pause 2,3 or 4 seconds depending on the regulation of second switch. In the second place I want the vibration of two seconds you will repeat continuously.
if u don't understand i will explaine...
