Circuit latch - I have spent a long time on this!
Discussion in 'The Projects Forum' started by shenker, May 19, 2009.
  1. shenker
    May 12, 2009
    I am trying to build a piece or equipment that disconnects a product (printer/fridge) from the supply at the peak of the AC wave using a low latency relay. I am almost complete but I am stuck where I have millisecond pulses 5V-0V which are at the same frequency as the input - 50Hz and in line with the sinusoidal peaks. What I want to do now is switch a button which means that at the next pulse (AC peak), the pulse will enter a latch which sets the ouput at 5V DC, even though the pulse continues to go between 0V and 5V, or maybe sits at 0V after disconnection. This is required to keep the relay open, not switch the relay on/off. I am thinking about something with BJT's or opamp positve feedback but I think this is a bit dodgy - anyone have any ideas? Thanks:)
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Can you post a schematic of what you have upto now?
    I think you need something to stretch the pulse.
    Greetings,
    Bertus
  3. shenker
    May 12, 2009
    Here is the schematic.
    I dont think a pulse stretch would work as there needs to be a very low delay and it needs to stay on for at least 3-4 seconds - You can see my NPN PNP transistor combination to try to achieve this, I dont really understand it myself, I just tried it out, actually it worked when I simulated it but not on the board.
    What do you think about some kind of positive feedback solution?
