Circuit is short while multimeter reverse probing
Discussion in 'The Projects Forum' started by Santhakumar, Apr 27, 2016.
  1. Santhakumar
    Mar 17, 2015
    33
    In My design i have a super cap circuit..in it i can see some weird things happening.
    it is 5V power rail..with multi meter impedance check with positive probe on 5V rail and negative probe on ground, i don't see any short ( it is around 12K ).
    but when i probe negative probe on 5V rail and positive probe on ground i am seeing short (0 Ohm).
    Does anyone faced this kind of problem.. Pls suggest me the reason behind this.
    santhakumar.
  2. wayneh
    Sep 9, 2010
    12,391
    3,246
    Your measurements will be artifacts if there is any voltage on those rails, such a residual charge on a capacitor. Or, an empty capacitor that large will look like a short for a very long time. On a smaller cap, you can see the apparent resistance increase as the capacitor charges.
    It's hard to say much without a schematic.
