circuit integrator for high frequency switching
Discussion in 'The Projects Forum' started by tira_othman, Jul 27, 2008.
  1. tira_othman
    Jul 23, 2008
    6
    hello everyone !!
    i was doing research based on this topic, but i couldn't find anything that satisfy me. i am looking for an integrator circuit, which has the clock (BJT) to control the high frequency dc switching. basically, this is for power electronics project.
    i supposed to do the input voltage feedforward pulse-width modulator for dc switching power converters. as for now, i need to find the integrator circuit which it can control the high frequency dc switching.
    anyone can help me ?
    thank u!
  2. tira_othman
    Jul 23, 2008
    6
    ok, i guess, everyone is not understand what am i saying .. so, this is the simulation picture, but i didnt get the sawtooth output as what my mission needs.
    so, pls help me with this .. i need to get an output like circuit integrator3 picture, but i must use transistor like circuit integrator4 .. but i cant get an output like circuit integrator3 .. can anyone really help me with this ?
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The dark blue of the channel B trace is extremely difficult to see; it appears nearly black to me, and I can't make out the waveform very well.
    Can you make it something brighter, or change the background of the O-scope to a more contrasting color?
  4. tira_othman
    Jul 23, 2008
    6
    this is the pictures for circuit integrator2 (int2) and circuit integrator3 (int3) .. i want circuit integrator3 to produce sawtooth waveform like the output from int2 .. :confused: the 1st picture is output from circuit integrator2, the second one is from the circuit integrator3 .. from the previous post, i mentioned about 3 and 4, im sorry, it was wrong, i meant 2 and 3 ..
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Could you have a problem with the bandwith? (the signal look rounded).
    Your experiment is using 3 MHz, pretty close to the unity gain bandwith.
    The LF356 has a unity gain bandwith of 5 MHz.
    The LF357 has a unity gain bandwith of 20 Mhz.
    The LF 357 has also a larger slewrate of 50 V/uS.
    Greetings,
    Bertus
  6. tira_othman
    Jul 23, 2008
    6
    this is what happened when i changed it to 5MHz
  7. tira_othman
    Jul 23, 2008
    6
    hello ..
    the purple is the output .. is that correct for the sawtooth output ? this is only for positive part since transistor is connected. Does this graph makes any sense ?
    i really2 need opinions here !! :confused::confused::confused:
