Circuit I proplem
Discussion in 'Homework Help' started by tinhnho, Sep 10, 2004.
  1. tinhnho
    Thread Starter Active Member
    Aug 31, 2004
    34
    hi everyone
    i have a trouble to do this proplem, even i already read the comment hints ,can anyone please help me with this proplem, Thanks for reading
  2. haditya
    Jan 19, 2004
    220
    is the answer 1/12 A??
    if yes just msg back and i'll give you the detailed explaination
  3. tinhnho
    Aug 31, 2004
    34
    CAN YOU PLEASE TELL THE DETAIL HOW TO GET THAT ANSWER ?THANKS ALOT
  4. haditya
    Jan 19, 2004
    220
    check out this attachment
    pm me if u have any further doubts
  5. tinhnho
    Aug 31, 2004
    34
    thanks alot for the answer, i just wonder how do you get resistance equal 12 ohm ? . Follow your picture which u drawn If i add resistor 1,2,3 to gether by parallel then it equal .333 ohm,the same with resistor 4,5,6 i have .333 ohm. For the branh with 6 resistor i have 6 ohm if add them togehter bye series: .333 +.333 + 6 = 6.666 ohm than it isn't equal 12 ohm like you said .i am not sure that i was right or wrong , if i did wrong just let me know. thanks
  6. haditya
    Jan 19, 2004
    220
    yup sorry my calculations are wrong
    the resistors of 3 add to give .3333
    and the 6 resistor set gives .1667
    so the net comes to .1667+.6666=.83333 ohms
    pls check my calc again and let me know
  7. tinhnho
    Aug 31, 2004
    34
    so the current Is = 1/.83333= 1.2A ? -->i think this may be the final answer
  8. tinhnho
    Aug 31, 2004
    34
    i think it should be -1.2A right ?
