circuit help
Discussion in 'Homework Help' started by AC/DC kid, May 21, 2013.
  1. AC/DC kid
    May 21, 2013
    Is this Low pass, High pass, Band pass, or Bandstop?
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    None of the above. You have not indicated where is the output of the circuit.
  3. Jony130
    Feb 17, 2009
    3,991
    1,116
    Where is the output terminal? Or load resistance? And what is your guess?
  4. AC/DC kid
    May 21, 2013
    I was thinking it was a Parallel resonant band-pass filter, but thats where i got confused seeing as it doesnt have an output. guess it is a trick question.
  5. Veracohr
    Jan 3, 2011
    559
    77
    If it's a homework question I suggest you not dismiss it as a trick question. I've missed points due to NOT making assumptions.
  6. AC/DC kid
    May 21, 2013
    It's a bonus part of a question, so that's also why i believe it to be a trick question as well.
  7. AC/DC kid
    May 21, 2013
    Actually now i see i was wrong in saying it's a resonant band-pass filter. there is a low pass RC and a low pass RL filter in this circuit. so if we assume that R5 is the load then wouldn't it be a Band pass filter?
  8. Jony130
    Feb 17, 2009
    3,991
    1,116
    Low pass filter + low pass filter = Band pass filter ? No, for sure.
    First assume for "low frequancy" that C1 is a open circuit and L1 is a short circuit"
    Next for "high frequancy" C1 is a short circuit and L1 is a open circuit.
    So what type of a filter we have if R5 = LOAD resistance ?
  9. bountyhunter
    Sep 7, 2009
    2,498
    507
    The first part (left hand) is resistors so it can be solved as a simple divider. To the right, you basically have a cap in parallel with an inductor. You should be able to figure what that does as frequency increases.
    This looks similar to a crossover network for a speaker.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    What is meaning of that resistor that is scribbled in series with the capacitor?
