Circuit HELP
Discussion in 'Homework Help' started by renegadegas, Dec 13, 2012.
  1. renegadegas
    Dec 2, 2012
    89
    Hello everyone,
    I need help in revising my attached design of a combinational digital circuit that will drive the F segment a seven segment display to use 2 input NAND gates please.
    Thanks very much.
    I appreciate your help.
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    Can you convert the basic 1 and 2 input gates (INV, AND, OR) into equivalent circuits that only use 2-input NAND gates?
    Can you convert a 4-input AND gate into an equivalent circuit that only uses the basic gates (INV, AND, OR) listed above?
  3. renegadegas
    Dec 2, 2012
    89
    I'm in a daze right now about your reply. I think iv been thought about it. i'll go look @ my notes.
    Appreciate your reply
    thanks a lot.
  4. renegadegas
    Dec 2, 2012
    89
    Yes i know the nand gate which is the AND with the zero @ the output and also having 1 input AND ( which is the 2 inputs joined together).
    Yeah I know those..
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    This wasn't what I asked. A "zero @ the output" is more properly called an "inversion bubble". The phrase "zero at the output" is too easily misinterpreted as meaning the logic value at the output is zero (a logic False).
    What circuit do you think is created by joining the two inputs of an AND gate together?
    Here are the questions I asked phrased a bit more explicitly:
    If I give you a box of 2-input NAND gates, do you know how to take some of them (how ever many you need) and construct a circuit that has the same input/output relationships as an inverter? As a 2-input AND gate? As a 2-input OR gate?
    Then, if I give you a box with nothing but 2-input AND gates, could you construct a circuit, using as many of those as needed, that has the same input/output relationship as a 4-input AND gate?
  6. renegadegas
    Dec 2, 2012
    89
    hahaa......
    you've knocked me into coma now. im new to electronics, please go easy on me. Im only just getting used to logic gates. i dont know what to say. i have to go read my notes and get back to you on that one.
    I appreciate your replies.
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    Here's a bit more of a hint.
    Take a 2-input NAND gate and tie the inputs together (which makes it a 1-input gate). What logic function do you get as a result?
    Now take a 2-input NAND gate and follow it with a 2-input NAND gate configured as described above. What logic function do you get?
  8. renegadegas
    Dec 2, 2012
    89
    the answer to the first question is a NOT gate.
    and the second answer is a double inversion at the output of the second one (or A into the first then A' at it's output then A' into the second and A at the second's output.
    Hope ive got them right.
    I like the way you challenge me. Its good to learn this way.
  9. WBahn
    Mar 31, 2012
    18,087
    4,917
    Correct.
    Remember, the first NAND gate does NOT have it's inputs tied together. It has two inputs, A and B. The output, call it C, of this gate then goes to both of the inputs of the second gate. The output of the second gate, call it Y, is the output of the overall circuit.
    So draw a truth table for the inputs A and B and the output Y for this circuit.
    You're on the right track, anyway.
    Good, because that's the way I generally operate. ;)
  10. renegadegas
    Dec 2, 2012
    89
    thanks very much. I 'll do that and let you know.
    Very nice to know there are people out here to helping
    novices like me.
    I'm off to work and you may not hear from me for a while
    as my shift can run for over 12hrs.
    Thanks very much again.
  11. renegadegas
    Dec 2, 2012
    89
    Helloo everyone,
    Ive been asked to revise my design to use 2 input NAND and i wondered if i was doing the right thing.
    I did the truth table and i have attached for anyone to view to see if im doing the right thing.
  12. renegadegas
    Dec 2, 2012
    89
    Helloo
    I did the truth table and i have attached that to my new thread as i cant find the attach button to put it on here.
  13. WBahn
    Mar 31, 2012
    18,087
    4,917
    Please don't start a new thread. To post the attachment, use the Go Advanced button at the bottom of the Quick Reply dialog box. Then use the Manage Attachments option.
  14. WBahn
    Mar 31, 2012
    18,087
    4,917
    I looked at your table. Go back and check on what the truth table is for a NAND gate.
  15. bertus
    Administrator
    Apr 5, 2008
    15,800
    2,386
    I have merged the two threads on the same subject.
    The posts will show in the timeline order.
    Bertus
  16. renegadegas
    Dec 2, 2012
    89
    Thanks very much for merging the thread. I appreciate it
  17. renegadegas
    Dec 2, 2012
    89
    Sorry I have been away working and im currently using my phone which cant do as much as a computer. Ill hav a look at the nand truth table again. Thanks a lot.
  18. renegadegas
    Dec 2, 2012
    89
  19. renegadegas
    Dec 2, 2012
    89
    Yes I made mistakes on the output c which should have been just the INV of the output of an AND gate . So state c output should be 1110 then output Y should be the INV of state C. So that should be 0001
  20. WBahn
    Mar 31, 2012
    18,087
    4,917
    And which logic function does that describe?
    In other words, a NAND gate with the two inputs tied together implements an INV gate. What gate does a NAND followed by an INV gate (constructed with another NAND gate) implement?
