circuit help
Discussion in 'Homework Help' started by scervany, Jan 4, 2010.
  1. scervany
    Jan 4, 2010
    6
  2. scervany
    Jan 4, 2010
    6
    anyone can help me ???
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This is homework help, not homework answers. Show us your work. You must be able to make a start at the problem, if only by a stepwise analysis of the procedure to reach the answer.
  4. Fraser_Integration
    Member
    Nov 28, 2009
    142
    5
    There are 4 essential nodes in that circuit, including ground node, so you can write 3 simultaneous equations by applying KCL at each of the e-nodes.
  5. hitmen
    Sep 21, 2008
    159
    Alternatively s/c voltmeter and o/c ammeter
    and add up the values
