Circuit Help
Discussion in 'The Projects Forum' started by £clipse, Oct 13, 2008.
  1. £clipse
    Oct 13, 2008
    Hi, I'm building a LED dimming circuit and i have a question about the schematic,
    http://www.reuk.co.uk/OtherImages/ne555-pwm-led-dimmer-circuit.gif
    On the far left under R1 I don't understand what the IN4148 is. Well let me rephrase that, I know what it is a 50k pot connected with two diodes(Germanium in this case) but I do not understand what the IN4148 means. Could anyone care to explain? Any help would be nice.
  2. mik3
    Feb 4, 2008
    4,846
    63
  3. £clipse
    Oct 13, 2008
    Thank you,
    I misread the page and it was talking about how ger. diodes can be put in place of the 1N4148 for more light out of the LED's. :(
    Anyways thank you very much for answering my question in a short period of time. Howver one last question, what do you think of this LED dimming circuit?
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    You can replace the 1N4148 with schottky diodes since they have a lower forward voltage like the germanium diode but are much less sensitive to temperature.
    hgmjr
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I don't think the forward drop of the diodes will make any visible difference in the circuit operation. If if works from bright to dim, what's not to like? Low component count is always admirable.
