Hi to the comunitee,
I am a mechanically trained tech with alittle electrical knowledge, and very little electronics knowledge.
I have got a small project here which I need alittle help from an expert if you could please assist with it.
Project is to monitor a lifopo4 hobby battery with the battery voltage monitor, this has the ability to program the battery voltage max and min voltage values, and alarm when the battery is above or below the set values, and when alarmin will audibl beep and also trigger a signal through the alarm port, which is an open collector output signal.
I want to connect this alarm signal to the relay pcb circuit to operate a relay to stop the battery charge process to try to stop the battery from overcharging, which is very harmful to the battery life.
I have purchased the relay pcb thinking it would work with the battery voltage monitor device, but have found out that it does not work. Is there anything i can add, or do to the pcb to make this little system work properly.
I have done alot of reading about the darlington transistors, and npn and pnp types of transistors, i thoiught what i have would work, but i have obviously made erros with what i have purchased, but am lookingto make it good. I can desolder the transistor out of the pcb and replace it with another type if required, can do this ok, just need to know what i need to do.
I have the circuits drawn below along with the pictures of both the battery voltage device and relay pcb.
many thanks for the help with this project.
Best regards, Anthony.
