Circuit for ping pong LED's
Discussion in 'The Projects Forum' started by Elsa13, Apr 7, 2016.
  1. Elsa13
    Apr 7, 2016
    Please help me in my project!
    I need a state diagram for this and final circuit.
    An example ping pong LED circuit display is given in the figure attached. It supports two different
    sequences (1 and 2). The state machine for this circuit will take an external input from the user to
    select one of the sequences. Once an input is applied, the selected sequence repeats itself as long
    as clock pulses are applied to the state machine.
    Design a state machine for a Ping Pong LED circuit.
    The machine should support at least two sequences and each sequence should comprise of at least three LEDs.
    Use switch(es) to apply input(s). The output of the state machine must be displayed on the LEDs.
    You may use any flip flop.
  2. Dodgydave
    Jun 22, 2012
    5,150
    769
    If its homework, post it in the homework section.
  3. Elsa13
    Apr 7, 2016
    Okay! Thanks :)
