Circuit for performing addition and subtraction
Discussion in 'General Electronics Chat' started by workingman, Aug 11, 2004.
  1. workingman
    Jul 11, 2004
    Iam trying a circuit that performs addition and subtraction on two single digit numbers given as inputs. Iam at a cross -please help.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you post the schematic? There's a number of ways to build adders and/or subtractors. We have to know your circuit before being able to advise.
  3. haditya
    Jan 19, 2004
    220
    voltage adder/subtractors can be built using opamps... do u want to build "analog" voltage adders or "logic" adder subtractors
  4. workingman
    Jul 11, 2004
    I want to build a logical circit that performs addition and subtraction on two single digit numbers given as input. I shall soon try to send a block diagram of it.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Does your project require reinventing the wheel, or can you use logic ic's?. A 74LS83, for instance, is a four bit full adder with carry. To do a subtraction, compliment the number to subtract, and add it to the other number.
    If you get the manual for LS TTL logic, you also get the internal logic of the chip, which describes how to build the function using AND/NAND & OR/NOR gates. If they're still using MIL-STD 806C logic symbology, that is.
