Circuit for converting vintage ammeter to voltmeter.
Discussion in 'General Electronics Chat' started by blkfrd, Nov 14, 2012.
Thread Status:
Not open for further replies.
  1. blkfrd
    May 10, 2012
    I have a vintage car that has a shunt ammeter. The needle sits in the middle and fully deflects in either direction for about 2A of current.
    I want to convert it to a voltmeter with an 8 to 16V range. A 12V reference power supply came to mind using a SEPIC DC-DC converter. The SEPIC supply is connected to one side of the ammeter and a current limiting resistor and the battery is connected to the other side.
    When the battery voltage is +/-4V different that the 12V reference and with 2 ohms of circuit resistance, 2A would be flowing and the ammeter would be fully deflected in one direction or the other. Current and subsequent ammeter deflection would be linear for < +/-4V.
    Problem here is that a SEPIC converter can't sink current. I could add a current sink transistor switch and resistor possibly that turns on only when 12V < battery voltage.
    4 switch Synchronous DC-DC converters can sink current, but this solution is expensive and i'm trying to find the lowest cost solution.
    What do you guys recommend? I thought of using a Power Op Amp, but I think it would require a V+ and V- power input. I'm a bit rusty on Op Amps so I can use some help though.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    I'd recommend not talking about it being in a car...;)
  3. bertus
    Administrator
    Apr 5, 2008
    15,808
    2,390
    Sorry, but we do not allow any automotive modifications here.
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
    PS @ tshuck, please do not do any recommendations to conceal a violation of the ToS
Thread Status:
