Circuit for a Crystal (and other related question) used with PIC18F2550
Discussion in 'Embedded Systems and Microcontrollers' started by KansaiRobot, Jun 29, 2015.
  1. KansaiRobot
    Thread Starter Active Member
    Jan 15, 2010
    318
    5
    Hello and thanks always.
    I am using the PIC18F2550.
    In my projects so far I have been using the Internal oscillator for non-USB projects and with for USB projects a board containing a PIC18F2553 (similar to 2550) and a crystal of 20MHz. Now the circuit outside OSC1 and OSC2 is similar to Figure 2-2 of the datasheet. crystal.jpg
    According to the recommendations of the datasheet with 20Mhz, C1 and C2 should be 15pF. However my board comes with C1 and C2 of 22pF. This does not represent a problem.
    Now I am planning of building my own board and I only have a 24Mhz crystal at hand. I have already found the changes of configuration I have to do to reproduce the 20Mhz behavior but my question is
    1) What value of capacitors is advisable to use?
    2) what for are these capacitors?
    The crystal I am planning to use is http://www.digikey.jp/Web Export/Supplier Content/Citizen_300/PDF/Citizen_HC49US.pdf?redirected=1
    Now, I found this page:
    https://blog.adafruit.com/2012/01/24/choosing-the-right-crystal-and-caps-for-your-design/
    in which they recommend C1 and C2 in a formula like C1=C2= 2*CL-2*Cstray but how much should I put for CStray??
    Now, my other question is in the Table 2-3 they give a series of oscillator configurations but since USB highsepped can only have 48MHz as clock , does this mean I have to always use PLL or use a crystal of 48MHz to directly drive it through USBDIV?? (see Fig 2-1)
    (Just in case, datasheet is here
    http://ww1.microchip.com/downloads/en/devicedoc/39632c.pdf
  2. ericgibbs
    Jan 29, 2010
    2,588
    389
    Your datasheet suggests a Cstray of 2 to 5pF, but as it states it depends upon your circuit layout.
    I would consider Cstray as 5pF.
    On the 18F2550 with a 20mHz xtal I use 12pF caps, I would suggest this value would be also suitable for your 24mHz xtal.
    For question #2, the PLL expects an internal 4mHz inputs, so using a 24mHz xtal would mean dividing by 6, see image.
    You can also set the CPU clock rate, using the PLL pre-scaler in CONFIG.
    E
  3. KansaiRobot
    Jan 15, 2010
    318
    5
    What for are these capacitors??
  4. ericgibbs
    Jan 29, 2010
    2,588
    389
    hi,
    This PDF explains the purpose of the capacitors.
    E
  5. GopherT
    Nov 23, 2012
    6,303
    4,020
    Are you asking "what are the 'stray' capacitors"?
    Stray capacitance is capacitance that your circuit has at various points even though there is no real capacitor present. It comes from pcb tracks running in parallel, and capacitance of various pins of components. In other words, if you add a 12 pF capacitor but your circuit behaves as though you have a 17 pF capacitor, then you have 5 pF of stray capacitance.
  6. KansaiRobot
    Jan 15, 2010
    318
    5
    thanks but no, I was asking what those capacitors (for example the 12pF) are for...
  7. GopherT
    Nov 23, 2012
    6,303
    4,020
    @KansaiRobot
    It is part of the filter that make the crystal resonate at the stated frequency. Granted, the filter is a bit tolerant because of the mechanical nature of the crystal but they are still required in many crystal oscillator circuits.
  8. KansaiRobot
    Jan 15, 2010
    318
    5
    Today I realized I forgot to put the conclusion here, for anyone who wants to use it.
    I used a 24MHz crystal with 2 20pF capacitors.
  9. shteii01
    Feb 19, 2010
    3,500
    511
  10. JohnInTX
    Jun 26, 2012
    2,393
    1,051
    KansaiRobot likes this.
