Hi
I have a circuit that I picked up as a kit from Maplin. The circuit works by turning the LED on if there is no 38khz IR beam detected. If a 38khz IR beam is detected, the LED shuts off.
I have a few questions about the layout of the design. I want to know if the R3, C7, R6, and R7 combination a filter circuit leading into the transistor?
The IC3 is a IR receiver. I read somewhere that the 1N4006 is a high speed switching diode. Because the IR receiver is picking up a frequency of 38kHZ does that mean that the diode is allowing a logic zero current through?
D2: 1N4006
IC3: TSOP2438
Q1: BC558
Q2: BC548
R2: 100R
R3: 220K
R4: 220K
R5: 10K
R6: 220K
R7: 220K
R8: 330R
C6: 4U7
C7: 100n
D2: 1N4006
IC3: TSOP2438
Q1: BC558
Q2: BC548
R2: 100R
R3: 220K
R4: 220K
R5: 10K
R6: 220K
R7: 220K
R8: 330R
C6: 4U7
C7: 100n
