Circuit explanation needed please.
TapOut64
Joined Mar 17, 2011
I had my electronics training back in 1984 and I seem to of forgotten more than I remember. In the following circuit, how is the +11V perm produced starting from U4 working to the left?
Any help greatly appreciated.
billbehen
Joined May 10, 2006
39
U4 flip-flops, u6 inverters boost level, xfmr blocked by C58, diodes rectifiy signal (smoothed by e'lytic,) r41 prevents core wandering, turns ratio set to put out +11volts. Maybe indicator maybe small amount of DC for something on another board:)
Adjuster
Joined Dec 26, 2010
2,148
The transformer is not being "tricked". The square-wave output from U6A U6B effectively is an alternating voltage, just not a sinusoidal one. The use of transformers to couple square or pulse waveforms is not all that unusual.
Whatever else the +11V may be used for, it feeds the input LED of an opto-coupler in what seems like some kind of start-up circuit.
If -PWR ON is joined to GND, the 11V will drive the input of OP1, so that Q12 will turn on, powering up +15VS and so the PWR ON LED, and in turn U7, and so +5V.
What is this circuit - some kind of remote control?
