Circuit Draining Batteries
Discussion in 'The Projects Forum' started by truwebs, Aug 27, 2016.
  1. truwebs
    Apr 2, 2016
    54
    Hello All,
    Been a while since I have been here. Have received some wonderful help here before, hoping I can get a little more help.
    I have created what I thought would be a very simple circuit using a string of battery powered micro led lights and a magnet switch.
    I placed a magnet switch inline to the circuit in hopes that the lights would turn on when a door is opened and then turn off when a door is closed. The circuit does appear to work as I had hoped. Lights do turn on and off as desired by opening and closing the door, but....
    After 12-24 hours I will open the door and the lights will not turn on. It appears the batteries have been drained. I have gone through 3 sets of batteries in about three days. What is happening? Hope you can give some insight.
    See images of items used and connection. This was supposed to be a cool feature of a restoration project I did. You can see the full project here.
    Thanks for your help,
    TRU
  2. noam ezra
    Jul 20, 2016
    7
    This relay work on a magnet ?
    Try to check his resistance when the door is closed
  3. Ylli
    Nov 13, 2015
    28
    9
    I'm a little confused by the way you have the switch wired. Do you by chance have the battery tied to the common and the NO, and then the LEDs tied to the same points? The LEDs would go on and off that way, but the battery would be shorted when the LEDs are off.
    You need to have the switch in series with the LEDs. Battery + to the switch common, switch NO to the LED string anode (positive lead), LED cathode (negative lead) back to the battery negative.
  4. BR-549
    Sep 22, 2013
    2,164
    415
    It appears to me that you have your batteries wired in parallel. Measure the current and install appropriate diode in each lead to the NO contact.
    Double check and make sure lights are really going off.
  5. truwebs
    Apr 2, 2016
    54
    See my drawing below. I believe there may be a resistor integrated into the battery pack after the battery pack switch.
  6. AlbertHall
    Jun 4, 2014
    2,252
    445
    That circuit will drain batteries as it short circuits the supply. Wired the switch like this:
    truwebs likes this.
  7. truwebs
    Apr 2, 2016
    54
    Thanks! Correction has been made. Light appears to be working as is should. If the batteries are dead 24 hours from now you'll be hearing back from me. ;-)
  8. AlbertHall
    Jun 4, 2014
    2,252
    445
    Fairy nuff!
  9. truwebs
    Apr 2, 2016
    54
    Since I was logged into the site just thought I would give an update. Circuit is working great! Batteries still have life!
    #12 likes this.
