Circuit Diagram Logic Probe
Discussion in 'General Electronics Chat' started by Kalagaraz, Sep 18, 2010.
  1. Kalagaraz
    Sep 18, 2010
    6
    Here is a circuit diagram for a simple logic probe in my digital electronics book I bought to learn electronics on my own.
    It says in book when switch is High or Low, only that LED will light, but I'm having difficulty visualizing this. Why can't current flow straight down on right side from +5v to GND at all times lighting both LEDs?
  2. Ghar
    Mar 8, 2010
    655
    72
    Current comes about from a difference in voltage.
    When the input is high, the top diode (plus resistor) is between 5V and 5V.
    There is no voltage difference therefore there is no current in the top diode.
    The bottom diode is between 5V and 0, so there will be current in the bottom diode.
    When the input is low, the top diode is between 5V and 0. The bottom diode is between 0 and 0.
    If the input wasn't connected both LEDs would be on.
  3. Kalagaraz
    Sep 18, 2010
    6
    Ok I'm still confused. Isn't the path from top to bottom 5v to 0v regardless of the input?
  4. Ghar
    Mar 8, 2010
    655
    72
    Well yes, the very top is 5 and the very bottom is 0.
    The middle node, output, is equal to the voltage given from the input.
    So when input is high, you have:
    +5V
    Top diode + resistor
    +5V
    Bottom diode + resistor
    When the input is low, you have:
    +5V
    Only elements between a voltage difference will conduct current.
  5. eblc1388
    Nov 28, 2008
    1,542
    102
    Yes, it certainly can. That's how it shows you the "undefined logic level".
  6. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
