Circuit Design
Discussion in 'General Electronics Chat' started by nanobyte, Feb 4, 2006.
  1. nanobyte
    Thread Starter Senior Member
    May 26, 2004
    118
    I have to design and simulate a circuit on multisim and I don't have a clue on how to go about it. I need to design a circuit below that will accept a signal in a range from 10kΩ to 100kΩ and output a voltage ranging from 0V to +5V. I know I'm going to need some op. amp. circuits, but from there I'm lost.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We're lost, too. What's the nature of the signal? The 10K - 100K you state is just the input resistance of the signal processing device. Does the signal need amplification, and, if so, by how much?
    An op amp and three resistors may do the trick, but we need more information.
  3. PointGiven
    Sep 10, 2005
    7
    Signals are not measured in ohms.
  4. chesart1
    Jan 23, 2006
    269
    Are you saying that an increase in resistance sensed at the input of the circuit must result in a proportional increase in the output voltage?
    John
