If I choose the Wheatstone bridge with 3x 100MOhm and the 4th resistor is my sensor I get voltage varies between 1.633582V to 0.291176V
The minimum acquired diff in voltage I need to be able to detect is 0.00573V (5.7mV)
If I put both V0- and Vo+ into a diff inst-amp (AD620) I can use Rg (Gain resistor) to increase the gain X2.
After the diff inst amp I believe I should put buffer amp and than into the ADC.
Is that sounds ok?
Is that sounds ok?
