As I was watering the garden yesterday, I noticed the rapid heating of the water in the hose from the sun. I thought if I built a thermistor based comparator circuit to cycle pool water through a black hose as it rose over 100 degrees, It would extend the swimming season, and be a cheap and neat project. The pump is a RULE 360, and uses 12Volts, 2.5A. I would use a rated power supply for mains isolation, and the 120vAC is on a GFI.
I have some IRF510's and TIP30's. The TIP30 is maxxed at 3A, so I was leaning toward the IRF510, and a 3906 pnp and LM339 comparator to drive it. (in the circuit, the switch is replaced by a LM339, and sinks very little current) Will this work? Multisim likes it, but I've found that simulations are nice for learning, but expierence makes it work. Any suggestions would be welcome. Thanks in advance.
