Circuit converter from 1A down 10mA
Discussion in 'General Electronics Chat' started by phucodientu06, Jun 29, 2010.
  1. phucodientu06
    Nov 24, 2009
    9
    hello everybody!
    I want schematic circuit converter current from 1A down 10mA
    please help me!
    thank you very much
  2. Dx3
    Member
    Jun 19, 2010
    87
    7
    You aren't making sense. Please try again.
  3. phucodientu06
    Nov 24, 2009
    9
    Hi Dx3!
    I have the schematic power 24V/1A but I don't known decrease current from 1A to 10mA ->24v/10mA
    please help me!
    sorry English bad!
  4. retched
    Dec 5, 2009
    5,201
    313
    Amperage is taken from a power supply, not given.
    If the power supply is CAPABLE of 1a, but the circuit only DRAWS 10ma, then no problem.
    Are you talking about 24vDC or AC?
    To limit the current that is drawn, use a resistor. A 2.4k ohm resistor will limit the circuit to 10ma.
    Are you using it for an LED?
  5. kingdano
    Member
    Apr 14, 2010
    377
    19
    do you want a regulated 10 mA 24V supply?
  6. Dx3
    Member
    Jun 19, 2010
    87
    7
    Sorry to disagree but...
    E = I R
    24 = .01 (2400)
    2400 ohms will allow .01 amps to flow.
  7. retched
    Dec 5, 2009
    5,201
    313
    Jeezuz.. I was only off by a little.. ;) (It was early...thats the only reason I can give for that OBVIOUS flub.)
    I have corrected the original post.
  8. phucodientu06
    Nov 24, 2009
    9
    Hi everybody!
    Thank you helped me
    I have the schematic power 24VDC/1A
    I want converter current from 1A to 10mA to use for sensor supply
    I hope everybody help me
  9. retched
    Dec 5, 2009
    5,201
    313
    The sensor only takes what it needs.
    2400 ohms will limit the current to 10ma.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, but if the load draws 5mA, the voltage across the load will only be 12V.
    Resistors are poor current limiters unless the normal output is unloaded.
  11. retched
    Dec 5, 2009
    5,201
    313
    True, Im having a hard time conveying the fact that the op doesn't need to 'dial down' the amperage rating of the power supply. The component will take what it needs.
  12. buckysparks
    Mar 30, 2010
    6
    can you post link, part number or datasheet of the sensor you would like to power?
  13. phucodientu06
    Nov 24, 2009
    9
    Hi everybody!
    below is datasheet sensor PT100
    can try use typical applications of L334?
  14. retched
    Dec 5, 2009
    5,201
    313
    The recommended excitation is 1mA not 10mA.
    Do you have a schematic on how you are using the device? What you are attaching it to to READ the thermocouple?
    Are you connecting this to a meter or to a microcontroller?
  15. Ron H
    Apr 14, 2005
    7,050
    657
    Did you mean LM334?
  16. buckysparks
    Mar 30, 2010
    6
  17. phucodientu06
    Nov 24, 2009
    9
    Hi everybody!
    thank everybody help me!
    I don't have a schematic on using the device
    If you have a schematic on using the device then can you give me,please
  18. Potato Pudding
    Jun 11, 2010
    684
    92
    Instrumentation engineering required?
    Your part is a type of Thermistor normally used for measuring cyogenic temperatures. Planning to send a sattelite into outer space and wanting to check the temperatures in the chassis, or if you need to make sure that a supercomputer bathed in liquid nitrogen is not overheating then these devices might be a good start.
    Looking at the performance graphs it seems to have a fairly level temperature sensitivity above about 90K of something around .35ohms/kelvin.
    Look for thermistor temperature measurement circuits. It will be used as part of a bridge or divider, as input sensed by an instrumentation op amp. There should be a callibration trimpot on the Op amp. The comparison reference and Op amp might use an oven to provide temperature stability.
    An Adc will convert the op amps amplified level to a digital signal and a microprocessor will need to be programmed with the device performance curve, especially under around 110K. The microprocesssor should use a lookup table or curve equation approximations and give you a temperature measurement based on the
    That is basically it. I don't think that is the answer you wanted but any circuit I could draw would be very general. It would be all about the calibrations and the programming.
    You could cut out the ADC and Microprocessor if you were happy using a coil meter across the Op Amp output to measure voltage.
  19. Ron H
    Apr 14, 2005
    7,050
    657
    Phucodientu06, as Potato Pudding suggested, tell us what you are trying to do. Then maybe we can help you.
  20. phucodientu06
    Nov 24, 2009
    9
    Hi everybody!
    Thank everybody help me!
    everybody look at circuit below
      File size:
      42.7 KB
      21
