Circuit change question
Discussion in 'The Projects Forum' started by ricker24, Feb 12, 2016.
  1. ricker24
    Mar 5, 2011
    53
    Found this circuit online and was wondering if it could be changed to count with a momentary switch instead of using the hall sensors?
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    You'll need to debounce the switches.
  3. #12
    Nov 30, 2010
    16,665
    7,310
    True. A millisecond isn't enough. Try 10 to 20 times that much capacitance.
  4. ScottWang
    Aug 23, 2012
    4,925
    777
    The debounce circuit just using two resistors and one capacitor, but I haven't try it with op amp, the 47nF change to 1uF and 220K change to 47K, and 47K connecting to another 47K to Ground, the switch is connecting from the common pin of two 47K to 4.7K as the pin 1 of hall IC.
  5. AnalogKid
    Aug 1, 2013
    4,685
    1,297
