Do be patient, I have several other functions to cover here and at home/work.
1. The amp illustrated might be superior to the first one you turned up. I have no EMG experience, so no expertise. I work with insects, but not quite at the level of straight electrophysiology. I suspect that vertabrate nerveous systems are somewhat differently organized - I know they are easier to get at without fatal harm to the organism.
2. The 10 pF is a short circuit to extremely high frequency noise that might be on one electrode lead and not the other. The only effect is to share it with both leads so it becomes common-mode (present on both), and therefore the instrumentation amp will ignore it.
3. If nerve signals to muscles are pulses, then eliminating DC and lower frequencies makes sense. I would want to find out more about any muscle group I was going to instrument to see if there was some superior way to read activity and correctly interpret it.
4. You may have a hard time assembling this project a piece at a time. Perhaps arriving at some working model with all inputs and outputs designated is better. Then you can shop for a processor that can handle the load. Otherwise, you may end up with several not well related mocroprocessors trying to share information.
