circuit board on tredmill to Saw
Discussion in 'The Projects Forum' started by greg1m53rg, Jul 8, 2014.
  1. greg1m53rg
    May 21, 2014
    Hi
    I am new and would be very thankful for any help !!
    I have a dc motor out of a treadmill that has a control board that does not work. {the one that adjusts the speed and incline} the circuit board works fine
    I would like to bypass the control so I can use this motor on my table saw.
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    You will still need a controller of some kind, look on ebay for KB or Baldor drives, they have the current limit and other features that you would need for any kind of decent control.
    Max.
  3. Dodgydave
    Jun 22, 2012
    5,144
    768
    How about a motor speed controller using a triac, need to upgrade the triac and bridge rectifier to suit the current.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    I second MaxHeadRoom's suggestion and have personal experience with KB drives for relatively small DC motors. BTW, that patent number cites a KB patent (5,066,884) as prior art. Nothing like sticking with what is known to work.
    John
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    nice pictures of board, but none of motor, is it an ac or dc motor? that would have a lot to do with the kind of drive needed.
  6. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    OP states DC.;)
    I have only seen one AC-capable motor on a treadmill and that actually was a Universal motor run in DC mode.
    Max.
  7. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    And treadmill motors are far too weak to run a table saw.
    Yes they do state1-2HP on the data plate, but this is not true, i have a motor thats larger than a treadmill motor and its only rated to 400 watts.
  8. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    Plus they do not reach the very high RPM's usually associated with circular saws.
    Any RPM increase using mechanical means would decrease the torque even further.
    Max.
  9. greg1m53rg
    May 21, 2014
    The motor is 5 hp dc
    that turns @ 5100 rmp
  10. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    5HP T.M. motor? Take it with a pinch of salt!
    If you compare it to high industrial 5HP DC Motor you can usually see the difference in size right away.
    Max.
