Circuit Board Night Vision
Discussion in 'General Electronics Chat' started by crecencio, Jan 15, 2006.
  1. crecencio
    Jan 15, 2006
    5
    Hello., if i paint all components, cables and electronic circuit path with phosphorus paint, can i get to see the current in a dark room lighthening the board. I think that heat come from all circuit board make glow the phosphorus paint and i can seing any troubleshooting before i make the restore work.
    Thanks .
    Crecencio
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Phosphorus does not glow from heat, and is somewhat dangerous to use. I'm not sure if you want to be able to visualize the circuit as a troubleshooting aid. If this is the case, digital cameras have sensitivity into the infra-red, and you might find that a camera will let you see what's getting hot.
    If you want to be traditional, turn off power and see which component burns your finger.
