Circuit board holder
Discussion in 'Electronics Resources' started by PatM, Dec 23, 2011.
  1. PatM
    Thread Starter Active Member
    Dec 31, 2010
    81
    72
  2. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    That is a nice set-up.
    You can always adapt the size of the holder, if you are working with larger PCB's.
    Bertus
  3. spinnaker
    Oct 29, 2009
    5,078
    1,180
    That is a really nice tool. Where do you get the materials?
    Or is this a kit that you purchase?
    The tool is fine if it is DIY with off the shelf parts but a bit junky if it is a purchased kit.
  4. PatM
    Dec 31, 2010
    81
    72
    You could do it yourself - or buy it.
    http://www.qrpbuilder.com/downloads/pcb_holder_you_can_build.pdf
    I have no idea where to get the parts or how much they would cost.
    If I were to try it, I think I would use some wooden dowels and some scrap oak pieces that I have handy.
    As long as it is only on a board with no electrical connection, I wouldn't think there would be any requirement to use ultra-high-molecular-weight polyethylene or nylon rods.
    Wood would serve the purpose but not be as durable.
  5. spinnaker
    Oct 29, 2009
    5,078
    1,180
    Oak wood make a really nice looking vice. I think I would use a screw like they use in regular vices instead of the rubber band to hold the board in place.
  6. K7GUH
    Member
    Jan 28, 2011
    191
    23
    Home Depot stocks clear plastic sheets which could be used this way. Some of my friends use plastic cutting boards which they trim to size with a table saw. The rods can come from a craft / hobby / art supply store. Of course, if you have a small table-top lathe, you can turn them from plastic cutting board scraps. Don't confuse plastic cutting boards with ceramic ones, as unpredictable results may occur.
  7. Llamarama
    Feb 1, 2010
    62
    I like this, very simple yet effective! Thanks for sharing! :)
