Hello Everyone!
I have a question of possible motives that would stop a power supply to work intermittently.
I have a Phillips Home entertainment system that I rarely use. The problem seems to be to somewhere in the power supply. It works for a few weeks/months and then it stops. The standby/power light wont light up and the unit is dead. I removed the cover and I hear something trying to start up for a split second then it stops. The fuse is good. The voltage to the unit is also okay. I took it apart last night and look for obvious signs of damage but there wasnt any. I come home this afternoon and it powers up like normally.
I was advised to check the transistors on the board when its not working. Does anyone have a plan of attack that might help solve this problem or has anyone ever had a similar experience with a power supply board?
Thanks for any help.
