Hi I Astabl Op Amp circuit (without chip 555) with a 50% duty variable frequency between 1K to 10k want - Dvstal please help me
In English please.Hi I Astabl Op Amp circuit (without chip 555) with a 50% duty variable frequency between 1K to 10k want - Dvstal please help me
I can't make heads or tails of what it is you have versus what it is you want. I'm pretty sure there are some English-as-non-native-language issues here, but we can work through those. So please reask your question, being a lot more specific as to what you are trying to find out. Keep in mind that we are probably going to struggle with your English and if we can piece together information from different parts of your post it will make that a lot more doable; it is basically an error correcting code -- we need quite a bit of redundancy to work around the language obstacles.Hi I Astabl Op Amp circuit (without chip 555) with a 50% duty variable frequency between 1K to 10k want - Dvstal please help me
You're not allowed to use 555... Is that correct? Only op-amps are allowed?I Astabl Op Amp circuit (without chip 555)
by Jake Hertz
by Duane Benson
by Jake Hertz
