It asks that initial condition current generators are used, what I believe models the circuit for t>0 is shown in the second picture with the switch open, and a current generator added. (I am not sure if this is correct.)
I then used KCL to write equations at node 1 and node 2.
Node 1:
\(\frac{5}{s}\) - \(\frac{2}{s}\)=\(\frac{V_{1}}{1}\)+\(\frac{V_{1}-V_{2}}{2s}\)
Node 2:
\(\frac{2}{s}\)+\(\frac{2}{s}\)=\(\frac{V_{2}}{1}\)-(\(\frac{V_{1}-V_{2}}{2s}\))
These can then be rearraged to give
\(\frac{3}{s}\)=\(V_{1}\)(1+\(\frac{1}{2s}\))-\(V_{2}\)(\(\frac{1}{2s}\))
and
\(\frac{4}{s}\)=\(V_{1}\)(\(\frac{-1}{2s}\))+\(V_{2}\)(1+\(\frac{1}{2s}\))
Which I then put into a matrix and solved for \(V_{1}\) and \(V_{2}\)
Giving
\(V_{1}\) = \(\frac{3}{s}\) - \(\frac{2}{1+\frac{1}{2s}}\)
which can be simplified to
\(V_{1}\) = \(\frac{3}{s}\) - \(\frac{4}{s+2}\)
and
\(V_{2}\) = (\(\frac{\frac{-3}{2}}{1+\frac{1}{2s}}\))+\(\frac{4}{s}\)
(*Note the 4/s is not part of the denominator, I couldn't get the brackets to work properly.)
Which can be simplified to
\(V_{2}\) = \(\frac{4}{s}\)-\(\frac{3}{s+2}\)
Then convert these back to the time domain to give:
\(V_{1}\)(t) = 3-4\(e^{-2t}\)
and \(V_{2}\)(t) = 4-3\(e^{-2t}\)
Can anyone tell if there is a mistake here or not?
I don't feel confident this is the correct answer. I think the 5 ohm resistor and 5A current should effect the circuit somehow but do not know how to encorporate it into my equations.
Node 1:
Node 2:
and
Giving
and
