Circuit Analysis Op amp
Discussion in 'Homework Help' started by damm1371, Mar 28, 2012.
  1. damm1371
    Feb 22, 2012
    11
    This is a practice problem for a test. The objective is to find Vo of the following circuit. All op amps are ideal. I have attempted to start by separating the op amps and calculating Vo accordingly. Starting with the top right op amp as 1. Vo1 = V1(1+R5/R4) and Vo2 = V1( 1 + [(R2+R3)/R1) so Vo would be Vo1+ Vo2
    this doesnt seem right. I am more interested in the process to get the answer than the answer.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Well see this method
    Va = Vin
    So
    IR1 = Vin /R1
    then
    Vb = (IR1 * R2 ) + Vin = (Vin /R1 * R2) + Vin = Vin*( R2/R1 +1 )
    And
    Vo = Vc
    IR3 + IR4 = IR1
    (Vo - Vb)/R3 + (Vc - Vb)/R4 = Vin/R1
    From this we solve for Vo
    Vo = Vb + ( Vin * (R3||R4)/R1) ) = Vin*( (R2/R1 +1) + (R3||R4)/R1)
    damm1371 likes this.
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    I believe you can "weld" R3 and R4 at the right ends (in parallel) since the voltages at the inputs of the second opamp are identical. Nodes which are the same voltage can always be shorted together.
  4. damm1371
    Feb 22, 2012
    11
    so maybe you can help me with this one as well. I tried to create a new thread for this but keep getting server errors. anyways...
    All components are Ideal for the following circuit. Calculate a value for R so that R dissipates maximum power. My first thought is to convert R2, R3, and R from Delta to Y, which gets very messy or is there a better way?
  5. vvkannan
    Aug 9, 2008
    138
    11
    Remove R and calculate the thevenin equivalent resistance as seen by the open circuit.For maximum power transfer the value of R should be equal to the equivalent resistance calculated
  6. mlog
    Member
    Feb 11, 2012
    276
    36
    Sounds right. I don't think R1 even enters the equation. Does it?
  7. bountyhunter
    Sep 7, 2009
    2,498
    507
    If R2, R3, R4 and R5 are the same ohmic value, "R" will dissipate ZERO power because there will be no current through it.
  8. damm1371
    Feb 22, 2012
    11
    let me know if this looks correct.
  9. mlog
    Member
    Feb 11, 2012
    276
    36
    Looks right to me. Delta-wye conversion. Obviously R1 is in the equation. And yes, bountyhunter has a good point.
