Circuit analysis help
MOS.EE
Joined Apr 21, 2013
9
I need help figuring out the lower and upper -3dB frequencies of the amplifier below. I must keep the answer in terms of the circuit components shown and the transistor gm, ro, Cgs and Cgd. Assume Cin >> Cgs, Cgd.
I must also consider channel length modulation.
power supplies: VDD = +5V, VSS = -5V
transistors: Vtp = Vtn = 0.3V and (k'W/L)p = (k'W/L)n = 1mA/V2
WBahn
Joined Mar 31, 2012
30,045
You need to show your best attempt at a solution (remember, it is YOUR homework, after all). We will then be happy to help steer you in the right direction.
This is not the Homework Done For You forum.
MOS.EE
Joined Apr 21, 2013
9
Well with this problem i'm not exactly sure where to begin. I know I should plot the pole against the gain. I was going to use the equation f = 1/2*pi*RC for the pole or frequency response, and find the total resistance for R, but i'm not sure if this is a good method for solving the problem.
MOS.EE
Joined Apr 21, 2013
9
I'm guessing you mean its T equivalent? Yes, I solved for that and from there I could probably find the gain and frequency, but i'm not sure what to do after I have those as far as finding the lower and upper -3db limits
WBahn
Joined Mar 31, 2012
30,045
Well, our crystal balls aren't good enough to see your work unless you post it. For frequency response questions, the pi model is usually more useful, but that's not a blanket statement.
