Circuit Analysis. Finding voltage. Possible trick question?
Discussion in 'Homework Help' started by VinceClortho, Mar 31, 2016.
  1. VinceClortho
    Mar 30, 2016
    20
    This is an extra credit question from my homework. Can someone spot a trick here or anything? My instructor likes to throw curveballs at us sometimes. How do I go about finding the voltage from A to B? EC.jpg
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    First find voltage at VA (voltage drop across R4) next find voltage at VB (voltage across R6) and final VAB = VA - VB.
    EDIT
    Also notice that R4/(R3+R4) = R6/(R5+R6) (voltage divider) so from there we can conclude that Vab = ??
  3. VinceClortho
    Mar 30, 2016
    20
    Thanks for the help. I came up with 200mV.
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    How ?? This is wrong see my additional note.
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    No. It is a trick question. Google Wheatstone Bridge.
  6. VinceClortho
    Mar 30, 2016
    20
    Here are my calculations. Would you mind showing me where I went wrong? EC2.jpg
  7. VinceClortho
    Mar 30, 2016
    20
    Disregard that "or 1.5V." It's not related.
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yep, (R5 + R6) are connected in parallel with (R3+R4). As I says early please notice that this two voltage divider (R3,R4) and (R5,R6) are the same. They have the same voltage ratio R4/(R3+R4) = R6/(R5+R6).
    https://en.wikipedia.org/wiki/Voltage_divider#Resistive_divider
  9. WBahn
    Mar 31, 2012
    18,085
    4,917
    Just remember that Vxy is short for Vx - Vy.
    So find the voltage at Node A (Va), Find the voltage at Node B (Vb). Then compute Vab = Va - Vb.
  10. WBahn
    Mar 31, 2012
    18,085
    4,917
    In this particular case, if you look at the values closely, you can answer the question by inspection. But, if not, just analyze the circuit as described above and you will get the answer. Once you do, then ask yourself if, in hindsight, there are things you could have spotted that would have led you to the same result with less work.
  11. VinceClortho
    Mar 30, 2016
    20
    Is the answer 0v? I calculated 72.2V across R4 and across R6. Another calculation came up with 79.38V across both branches (R3 and R5 included). Either way it suggests The voltage across the branches are the same which is how it should behave according to what was suggested earlier about the ratios (not to mention the nature of parallel circuits in general). I hope I'm not missing something.
  12. crutschow
    Mar 14, 2008
    13,482
    3,369
    You are missing the fact that the answer can be determined by inspection.
    You don't need to do any calculations, just observe the the voltage division ratio of R3 and R4 is the same as R5 and R6 so the voltage difference is 0V.
    If you did the calculations and came up with some small voltage due to rounding errors in your calculation, some profs will take points off your (not quite correct) answer because you didn't observe that it should be 0V. :rolleyes:
  13. VinceClortho
    Mar 30, 2016
    20
    Thanks for the help everyone.
  14. MrAl
    Distinguished Member
    Jun 17, 2014
    2,553
    515
    This is not a trick question...balanced bridges are a fact of nature...it happens. In practice there may be a small difference, but in theory we can theorize that there is absolutely zero difference. Another way of putting this is that a balanced bridge is "unobservable".
    If you have never dealt with resistive bridges however this may be new to you, so you just have to carefully calculate the two voltages and then subtract. Sometimes polarity matters, so Vab=Va-Vb and Vba=Vb-Va, although there may be cases where they are both the same (ideally). I dont want to give out too much just yet though.
