Circles
Sparky49
Joined Jul 16, 2011
833
Hi everyone,
now I know this is easy peasy for you guys - but bear with me!
I'll write out the whole question first.
7. A circle with centre C has equation \(x^{2}+y^{2}-4x+12y+15=0\).
a) Find:
i) the coordinates of C;
ii) the radius of the circle.
b) Explain why the circle lies entirely below the x-axis.
c) The point P with coordinates (5,k) lies outside the circle.
i) Show that \(PC^{2}=k^{2}+12k+45.\)
ii) Hence show that \(k^{2}+12k+20>0\)
iii) FInd the possible values of k.
Phew!
I completely understand parts a and b, but c has confused me a little. I've tried thinking about it (alot!) but I am just unsure as to what approach I need for c. It's only worth a couple of marks, so it should be fairly easy - but I'm not seeing what I need to do!
Could you point me in the right direction?
Thanks,
Sparky
DerStrom8
Joined Feb 20, 2011
2,390
Just graphed it - but I'm unsure what I'm supposed to do from here.
Sorry about that.
After you graph it, you should get a better picture of what it looks like. From there, it's mainly just plug and play. Insert the values (k is the y value of the center coordinate; center is (h,k)) in the formula and show that it gives the correct result. Then, find where the circle intersects the Y axis (find possible values of 'k').
I hope this helps. Good luck!
Regards,
Der Strom
Sparky49
Joined Jul 16, 2011
833
Okay, I think I'm understanding this more - but what values are P and C?
They are points - not numbers?
Sorry if I'm being a bit - slow.:(
Sparky49
Joined Jul 16, 2011
833
No problem!
I got the rest pretty quickly - it was mainly the twisted notation which confused me. It suddenly clicked that CP'2' was the radius squared!
