Christmas lights that are only operated by only 12 v battery
Lightfire
Joined Oct 5, 2010
690
I am planning to make a Christmas light which can be used on a 12 volts battery.
The circuit includes:
8 pieces of 1.5 volts Christmas light (one bulb)
A wire
and a 12 volts battery...
1.5 volts times 8 equals 12???
so, it is possible to work???
Anyway, I saw that a normal Christmas single light is about 2.5 volts so if I put 8 pieces of 2.5 volts Christmas light bulb, it will not be bright anymore. Because 2.5 x 8 is already 20 :( And I only had 12 volts battery. :p
P.S. My circuit will be on a series circuit...
Thanks :p
wayneh
Joined Sep 9, 2010
17,498
Are your bulbs "regular" bulbs, I mean NOT LEDs?
If so, your circuit should be fine. LEDs are less simple to use because they will make little or no light at low voltages, but will be quickly damaged at higher voltages.
Like many strings of lights, your's will go dark if any one of the bulbs fail to complete the circuit because of a bad connection, or if it's burnt out.
Bernard
Joined Aug 7, 2008
5,784
Why not use two strings of 5 bulbs each, from 50 bulb string,? Most current bulbs short when burned out- or maybe 4 out of 5 burn-outs.[ experience of 260 bulb flag over 5 years.] If bulbs are taken from a 35 bulb string, about 3.4V ea, then 2 - 4 bulb strings can be used.
