Christmas Lights in a Car
Discussion in 'The Projects Forum' started by JellyWoo, Dec 10, 2013.
  1. JellyWoo
    Jun 2, 2013
    12
    I bought a set of Christmas lights. They are powered by 3 AA batteries, for a total of 3.6 volts. I would like to use these in a car by connecting them to a car charger like this one. The adapter uses a microUSB cable and outputs 12 to 14 volts (I think?). Is it possible to somehow remove the battery pack from the lights and connect it to the microUSB cable and add some resistors? I have a good soldering background, so that wouldn't be a problem, but I'm a little iffy with the electronics.
  2. KJ6EAD
    Apr 30, 2011
    1,426
    363
    USB outputs are by definition 5V. You can usually modify the DC/DC converter to output the voltage you want but you might do well to simply put a rectifier diode in series to drop the 5V down to 4.4V.
  3. mcgyvr
    Oct 15, 2009
    4,784
    973
    3 x 1.5 = 4.5..
    Its probably close enough to just use the charger directly without a diode even..
  4. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    Atleast where i live, its illegal to put lights in a vehicle, though many truckers but these christmas light stuff on the dash anyways.
    mcgyvr likes this.
  5. KJ6EAD
    Apr 30, 2011
    1,426
    363
    True, considering the fact that new alkaline cells often measure as high as 1.7V each without a load.
  6. JellyWoo
    Jun 2, 2013
    12
    Disregarding the legality of the lights, what I'm getting at is that i can solder the lights directly to the USB cable without any diodes or resistors?
  7. wayneh
    Sep 9, 2010
    12,368
    3,224
    I'd add the diode or a low value resistor. Without it, your string will likely work perfectly for a while but it's life may be shortened. It's hard to tell without more details, but if it was designed for 4.5V, a 10% increase in voltage and current might stress it. If you don't care too much if it burns out early, just go for it.
  8. JellyWoo
    Jun 2, 2013
    12
    I'd prefer for it to last a while. What details would you need/what diode or resistor would I need?
  9. wayneh
    Sep 9, 2010
    12,368
    3,224
    Your diode needs to be rated for the current drawn by the lights, plus a nice safety factor. I'm guessing a 1A diode would be fine, for instance 1N400x. Readily available at Radio Shack. But do check the current drawn by your lights.
  10. JellyWoo
    Jun 2, 2013
    12
    How do I check the current drawn by the lights?
  11. JellyWoo
    Jun 2, 2013
    12
    (Sorry I'm a noob at this.)
  12. #12
    Nov 30, 2010
    16,663
    7,307
    Get a $4 digital multimeter at Harbor Freight and measure the current.
  13. JellyWoo
    Jun 2, 2013
    12
    Okay, so I know I need a resistor to limit the current. Do I also need a voltage regulator to limit the voltage? What is the purpose of the diode? I'm a little confused.
  14. #12
    Nov 30, 2010
    16,663
    7,307
    It's either/or. A diode will use up about .6 to .7 volts and thus lower the voltage a bit just by existing in the circuit. A resistor would have to be calculated by measuring the current so it uses up the right amount of voltage.
    Opinion: Don't buy the meter, don't calculate the resistor, just stick a diode in and be done with it.
  15. JellyWoo
    Jun 2, 2013
    12
    Why do you suggest not using a resistor?
  16. #12
    Nov 30, 2010
    16,663
    7,307
    Because you have to buy a meter and measure the current to calculate the resistor size.
  17. JellyWoo
    Jun 2, 2013
    12
    So if I did have access to a meter, it would be ideal to use both a diode and a resistor? Would they be connected in series?
  18. KJ6EAD
    Apr 30, 2011
    1,426
    363
    No, not both; just use a diode.
  19. JellyWoo
    Jun 2, 2013
    12
    Why not both? Don't the two limit different things?
  20. KJ6EAD
    Apr 30, 2011
    1,426
    363
    That's actually a good question. They limit the same thing (current) in different ways.
    http://en.m.wikipedia.org/wiki/Diode
    A diode drops a certain voltage dependent mostly on it's construction materials but a resistor in a series circuit drops a voltage that varies as a function of the current passing through it. This current is dependent on the properties of other circuit components which are in the present case only partially known.
    JellyWoo likes this.
