choosing wire size
Discussion in 'General Electronics Chat' started by Dougm, Apr 19, 2007.
  1. Dougm
    Apr 19, 2007
    Can anyone tell me what size wire I need for a 3 phase, 240V, 30A AC electric motor?
  2. recca02
    Apr 2, 2007
    1,211
    are u talking about windind wires? if connecting wires
    i think specifying the current shud be good enough to buy a wire.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  4. Dougm
    Apr 19, 2007
    This is stranded wire.
  5. Dougm
    Apr 19, 2007
    Beenthere: the chart does not indicate the wire voltage.
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Wire voltage is limited by insulation type and thickness, not by wire size. Regular THHN insulation is good for around 600 Volts
  7. windy
    Member
    Apr 19, 2007
    26
    as far as voltage wiresize is not figured on wattage it is figured on amps. No matter what voltage you are using the wire size is per amps. your wire size will also figure in for start current and pf of the motor, as well as distance from the panel. No matter how short the distance from the panel use the wire size in your chart. Calculate the wire size if over the distance limit.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Rule of thumb is 700 circular mils per Ampere
