I had bookmarked this post for a looooong time for me to read it when I would have more peace of mind.Well, @MrChips... it seems that the time for me to contribute something of real value to this forum has finally arrived... What I am to give away has cost me years of research and practice and endless headaches... But I've been helped so much by the members of this forum that I'd be nothing short of an egotistical fool if I were to keep this to myself only.
For a long time I tried to develop a quick and reliable way of producing PCBs in my own workshop with mixed results. I tried toner transfer, photo-etching, screen printing, direct printing, etc... and I failed miserably on some of them, and had mixed results with others... UNTIL...
I discovered the holy grail of toner transfer using a paper especially designed for ceramic and metallic surfaces.... I'm not exaggerating.
The paper is called M3 [M-Cubed] Transfer Paper, and it's sold by QLT. They are the only suppliers that sell this miracle paper.
It is not cheap, it costs $60.00 dlls for a pack of 100 A-size (8.5" x 11") sheets, but the price is not off the roof either, especially when you consider its capabilities.
Its performance is, at least for me, nothing short of miraculous. The paper peels off with the greatest ease, does not leave residue on the surface, and does not need to be submerged in a water tray for it to be removed.... Just print, press and peel.... and you're ready for etching.
But you need to know how to use it... and it helps tremendously to have your own heat press, instead of trying to use an ordinary iron. Trust me, the investment is very much worth the results.
So without much further ado, here's the process in full detail.
- After designing your circuit, print it using a laser printer (not inkjet, nor laserjet, nor any other type of printer that does not use toner) that does not heat the paper when it prints it. Most old laser printers have a built-in hollow roller tube that has a heating element inside whose purpose is to heat the sheet as it passes through, so as to fuse the toner to the sheet.... You cannot use this kind of printer for this application or the paper will fuse to the roller and make a mess inside your printer. What you need to get is a printer that uses laser-diode technology that will only heat the spot on the paper where the toner is, and not the entire sheet. I own an Okidata C3400n Color LED Printer that does the job nicely. Unfortunately this specific printer has been discontinued, but there are many newer printers out there that will work just fine for this... just make sure that your printer uses laser LED technology.
- Set the printer for maximum resolution and heavy paper, And use the color red for printing all of your circuit's traces. This color of toner is the one that I've found to be the most etch resistant. You may try using other colors (including black) at your own risk.
- Preheat the heat press to 350°F
- Clean the FR4 using a degreasing solution, and dry thoroughly. I like to use Windex for that.
- Make sure that the FR4 is completely clean and that it doesn't have any fibers or dust particles, or tiny pieces of paper towel, if that is what you used to clean it with. If there are fibers or dust on the FR4, then try blowing them off, but do not touch it with your fingers, if you can avoid it.
- In the heat press, place a 1/8" thick sheet of silicon red rubber on top of the FR4 copper clad laminate (I've found that a size of 6" x 4" 2mm thick works best) and preheat the FR4 by pressing it for 75 seconds.
- After the FR4 has been preheated, lift the silicon rubber and allow it to cool for a couple of minutes. You don't have to remove either the rubber nor the FR4 from the press for this. Just roll the rubber sheet back to expose the FR4 and allow it to cool a little bit, but no longer than two minutes.
- Cut the 4 x 6" circuit out from the sheet that you just printed. I recommend leaving an extra 1" flap of paper in the final cutout, this will leave you with a rectangle measuring 4" x 7" that contains the circuit. This makes it a lot easier to peel the paper off later on.
- Place the printed sheet on top of the FR4, and then place the silicon rubber back on top of that.
- Press for another 75 seconds.
- Remove the rubber sheet from the press
- Using something other than your hands (I use a cooking spatula), remove the PCB from the press.
- Allow the PCB to cool to room temperature. This takes a little over 5 minutes. You can blow some air on it with a ventilator to cool it faster, if you want.
- Peel the paper off the PCB, and make sure that all traces are perfect and that none of the ink has remained on the paper. If some little bits of ink remained on the paper (which shouldn't have happened, if you followed my instructions carefully) then retouch the traces at the PCB using one of those stinky permanent ink markers.
- Voila! You're done! You're ready to etch your PCB!
- After etching, do not try to remove the toner from the PCB using a solvent or anything else. Just let the toner be. Do all the drilling that is necessary and soldier all the components on the board, without doing a thing about the toner. The toner will melt away when you apply the solder and all of your components (including SMT caps and resistors) will be soldered with ease. The only exception to this might be SMT chips. For this case I recommend scratching the toner off the PCB at the place where the chip will be installed, and tin those traces with a little solder so you can later solder the chip by gently pressing each pin to its corresponding trace with the soldering tip. This takes some practice to master, but I've done it with chips that have a pin spacing of only 0.025".
- Also, leaving the toner on the PCB will better protect the traces from corrosion due to moisture.
In a later post I plan to show how I built my etching tank, especially designed to process the PCBs quickly, and using the least possible amount of Ferric Chloride (Iron [III] Chloride, FeCl3).
- One last thing. The transfer paper has a shelf life of about two years. After this time, it becomes harder and harder to peel off, and it might even begin to jam in the printer, which is a real nuisance since you have to open the thing and carefully remove and clean the mess that has stuck inside.
I'll be the first to admit that the results are nothing but astonishing but (everyone has a but to provide) I'm not completely sold, based on the cost of the procedure.
For the cost of the special paper ($65+shipping) and the cost of the heat-press, let alone the case where you have an old, unsuitable laser printer, I think the photo-sensitive boards are a better bet.
Granted, the boards themselves are more expensive to boot (about double the price: grobotronics.com/prototyping-cooper-board-100x75mm.html vs http://grobotronics.com/100x75mm.html), but you can print a transparency even at a photocopy machine and you can find a UV chamber under $100, much less if you build one yourself.
But that doesn't let me admire in awe when someone gets the procedure that has tormented many evenings of mine, digging paper residue off the PCB with a toothbruch, just perfect. Congrats!
