choosing the right comparator
Discussion in 'General Electronics Chat' started by nully000, Jun 14, 2013.
  1. nully000
    Jun 14, 2013
    hy there, i'm new to electronic and need some help. i want to use a comparator to measure some voltage in micro or nano dimensions, and dont have an oscilloscope. i cannot get the information i want from the data sheets. does any one know a micro controller that can compare micro volts or even better help me understanding these sheets where to look etc
    thanks in advance
  2. Andreas
    Jan 26, 2009
    68
    Generally we talk of mV (milli Volt), uV (micro Volt) and pV (pico Volt) but not nano Volt.
    So you want to compare two voltages down in the microVolt region using a comparator IC (chip) or with a microcontroller?
    Some more descriptive information is required. Such as data sheets, device types, circut schematic, application etc.
    P.S. If you wanna get serious about electronics then an oscilloscope is pretty much a necessity.
  3. nully000
    Jun 14, 2013
    all i need is the name of a cheap chip that can compare two voltage in uV region or even better, can most of these chips do that, and cannot afford an oscilloscope for the moment, will have to do with out
  4. crutschow
    Mar 14, 2008
    13,475
    3,361
    Generally comparing voltages in the μV region is dicey. Can you amplify the signals before comparison?
  5. nully000
    Jun 14, 2013
    i was already thinking about it, but would prefer to avoid this solution
