Choosing Load dump diode for truck power supply
Discussion in 'General Electronics Chat' started by vam3kor, Jul 26, 2011.
  1. vam3kor
    Jul 18, 2011
    5
    I am designing a power supply for Truck application of 28V battery system, I need to choose a load dump diode to place across battery line.
    how to calculate its peak power, energy, etc.
    Load dump clip voltage is 40V,
    load dump transient spec
    Vs= 176 V
    Ub= 28V
    Ri = 2 ohms
    Td= 400ms ( pulse duration)
    Tr= 10ms ( 10 to 90% rise time)
  2. lokeycmos
    Apr 3, 2009
    432
    7
    could you give more info about your setup and what you want to accomplish? are you putting the diode across the terminals of the battery? if you goto digikey's website you can click on the specs you need and if they have it in stock check the prices.
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=4261062
    vam3kor likes this.
  3. #12
    Nov 30, 2010
    16,665
    7,310
    The way I see this is that a 40 volt limit will be placed on a surge with the same polarity as the 28 volt battery. That is, the 28 volt battery shall not be allowed to have more than 40 volts at its terminals when a 176 volt generator with 2 ohms of impedance surges for 400 milliseconds.
    176-28 = 148V
    148/2 = 74 amps max
    times .4 seconds = 29.6 amp seconds, and I think that's "joules"...or are joules watt-seconds?
    Problems: I'm getting squat for a single device that can do that.
    The battery should contribute quite a lot to quenching this surge, so the math here is very conservative.
    asking for clarification from vam3kor
    vam3kor likes this.
  4. vam3kor
    Jul 18, 2011
    5
    Thanks you for your replys
    I'll come up with some more info
  5. vam3kor
    Jul 18, 2011
    5
    I need to choose a TVS diode to clip the transient above 40V, So the TVS diode should be able to consume the energy grnerated by the transient
    As you told the voltage of the signal is 172-40= 132V
    Resistance is 2
    so current is 132/2= 66A
    Now how to calculate the exact power of this signal ?
    because its going to be a half sine wave with amplitude of 132V and Current 6A
    is the below way is correct?
    RMS value of the voltage is (Vm/√2)=132/1.414
    RMS value of current is (Im/√2)= 66/1.414
    I don't know how to calculate power from this information.
    Is Sinθ info required?
    Load dump transient waveform attached
