Choosing capacitance for peak detector
Discussion in 'General Electronics Chat' started by anhnha, Dec 25, 2015.
  1. anhnha
    Thread Starter Active Member
    Apr 19, 2012
    776
    48
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    the value of the capacitor for the dector depends on the speed versus the accuracy.
    A small capacitor will make it fast, but leakage will let the voltage drop.
    A large capacitor will make it slow, but it will keep the maximum value much longer.
    Bertus
    anhnha likes this.
  3. anhnha
    Apr 19, 2012
    776
    48
    Thanks for the answer!
    I think time constant RC is what relating to speed and accuracy here?
    With RC is small, it will charge and discharge fast.
    Is there a detailed treatment of this? I tried to search but couldn't find a good one.
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    A peak detector is used for keeping the maximum value of a signal.
    An envelope detector will follow the changes in signal.
    The following pdf will give you more info on the envelope detector:
    http://educypedia.karadimov.info/library/tut331_04am_dem.pdf
    Page 6 will tell you about the effects of the RC time.
    Bertus
    anhnha and RRITESH KAKKAR like this.
  5. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Vc=5(1-e^-t/RC)
  6. anhnha
    Apr 19, 2012
    776
    48
    Actually, I am using the structure (peak detector) as a rectifier. So, I think there should be a balance here.
  7. MikeML
    Oct 2, 2009
    5,450
    1,066
    The simplistic peak detector shown in chapt 3 is missing a crucial element, which is a discharge path for the capacitor. The effect of the discharge path (load) must be factored into the charging time, as well as the discharging time...
