Choosing a crystal.
Discussion in 'Embedded Systems and Microcontrollers' started by Gibson486, Jun 16, 2016.
  1. Gibson486
    Jul 20, 2012
    199
    12
    I am trying to pick a crystal for an ARM processor.
    Originally, I was going to use this:
    http://www.abracon.com/Resonators/abls.pdf
    but I ran out of space. As a result, I am thinking of using this:
    http://www.txccrystal.com/images/pdf/7a.pdf
    I am sort of confused, because I am not sure what I lose from going to one to another. I noticed that the first one listed Microprocessors as an application, but I am guessing that is for marketing and the other one will work as well? Also, I am assuming that the ARM cannot drive over 200 uW spec on the 2nd crystal. I am hoping that it really does not matter just as long as I get the caps to go with it correctly.
  2. joeyd999
    Jun 6, 2011
    2,759
    2,944
    Underdriving a crystal is rarely a problem. Overdriving fractures the crystal. The second choice should work fine.
    Crystal circuits on modern MCUs are easy today. Not like the old days. Just about anything works well.
  3. Gibson486
    Jul 20, 2012
    199
    12
    Nice....Thanks!
  4. AlbertHall
    Jun 4, 2014
    2,290
    451
  5. dannyf
    Sep 13, 2015
    2,196
    417
    It is unlikely wise to assume. In general, you look for frequency, stability, packaging, price, etc.
    I typically look for small load capacitance, 5 or 6pf ones are good in that the parasiticc capacitance would be sufficient.
