Choose MOSFET for stepper motor driver
Discussion in 'General Electronics Chat' started by blackind, Jan 14, 2011.
  1. blackind
    Nov 25, 2010
    5
    Hello, I want to build a driver for a Stepper motor which runs on 4,7 Volts and 1,8 A per phase. Do you know of a MOSFET that can do this job? There are so many in the market, I really don't know which one to choose...
    Here's a schematic, the voltage of the source hasn't been decided yet, we want it to be as small as possible
  2. blackind
    Nov 25, 2010
    5
    In case of being misunderstood, by source I don't mean the source of the MOSFET but the Voltage applied on the left of the schematic, from the drain ti the ground.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Without knowing what your Vdss specification will be, making a decent recommendation will be very difficult.
    You say 4.7v; is that the gate control voltage that's available? All logic-level MOSFETs will work with that.
    Is the stepper motor bipolar, unipolar, or actually a BLDC motor? Posting the manufacturer and part number or a link to the datasheet will be most helpful.
    blackind likes this.
  4. blackind
    Nov 25, 2010
    5
    Each phase of the motor should be carrying 1,8A through its resistance (2,6 Ohms), so the voltage across its coil should be 1,8 X 2,6 = 4,7V. The supply voltage of the circuit should be 4,7 + Vds (drain to source). We would prefer Vds to be smaller than 4,7 in order for the MOSFET to be less consuming. A clip from the motor's datasheet has been attached with a connection circuit. The circuit won't be the same, instead of transistors we are going to use MOSFETs. The motor's maximum speed won't be more than 1000 steps/sec.
    Any ideas about which MOSFET to choose?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    For "As Small As Possible" - SI5406CDC
    20V Vds
    6A continual current
    1.5V Vth turn on, so 4V would switch it well.
    6Watts dissipation - Mount on large copper pad for heat sinking.
    Size is 2mm x 3mm, smaller ones are available, but would require reflow soldering as they are in a BGA type package.
