AFAIK the PICAXE uses a chip from Microchip, which CodeVision does not support. You need to be more specific about your requirements for I/O pins. I would start by looking an the ATtiny series of parts.I look for avr IC with few I/O pin and has interrupt pin , I found PICAXE-14M but I use codevision to program IC and I didn't found it library for codevision,has it library??
what IC suggestion am I use ???
try ic may you know more ones than you know no.what IC suggestion am I use ???
SNARK SNARK -- what does this even mean?try ic may you know more ones than you know no.
https://en.wikipedia.org/wiki/Atmel_AVR_ATtiny_comparison_chart
Here is one with only 4 pins
http://www.atmel.com/images/atmel-8...ttiny4-attiny5-attiny9-attiny10_datasheet.pdf
by Jake Hertz
by Duane Benson
by Aaron Carman
by Duane Benson
