Choose appropriate wiring
Discussion in 'Homework Help' started by Pass1234, Mar 11, 2009.
  1. Pass1234
    Mar 7, 2009
    My Sumo-Chef 3000 blender caught on fire. I fixed up the motor and base, but the cable needs replacing. Using aluminum conductors, please size a standard cable size if my blender uses 220 VAC, is 3 metres from the outlet, and the blender is 1 HP. Is your cable size appropriate for chassis wiring? Explain your answer.
  2. b.shahvir
    Jan 6, 2009
    444
    In my opinion, using aluminium conductors is sacrilage!! :eek:
  3. KL7AJ
    Nov 4, 2008
    2,047
    295
    Alas...having traveled extensively in Thailand and Burma, I've discovered that aluminum line cords are indeed prevalent, as I imagine they might be in India. This is by no means the SCARIEST aspect of much Asian wiring. I was in a hotel in Mae Sot. They had ON DEMAND water heaters INSIDE THE SHOWER, fed with a piece of ROMEX!!!!! And they run 220 everywhere, to boot! I guess that's how they keep the tourist pouplation in check. :eek:
    Eric
